BecauseScience
- Oct 9, 2005
#1 Can the DS-24E be set sideways (tower style) on a shelf? I'm concerned about the plastic rail that extends from the handle. It would be going onto steel (Metro) shelving.
#2 Is the only difference between the DS-24E and DS-24ER the redundant psu?
#3 Is it possible to buy a DS-24E without a psu? I'd like to put a Seasonic gold or platinum in there.
#4 Are there any issues with Intel m1015's and the internal expanders in the DS-24E. I'd obviously need a bracket to take the internal sas to external.
#5 I would replace the stock fans with Nexus D12SL-12's. The DS-24E would be located about two feet from the desk where I work. Would it be quiet after the fan swap? I have a few machines in Fractal Define cases with Nexus D12SL-12's in the same spot the DS-24E would occupy. I'm trying to achieve roughly the same noise level with the DS-24E.
