Quick noob question - please help.
name
Quick noob question:
Ok, so my P4 has a 533mhz fsb, 133mhz "quad pumped" to 533. Does this mean that, before I do any OC, my ddr 400 memory is running at 133mhz? Or does it run at 200mhz, regardless of fsb, until I OC the fsb beyond 200mhz (at which point the memory would run at the same speed as the fsb, assuming no fsb:memory ratio is used)? Help would be appreciated, thanks in advance.
yes, your ddr400 is running at 133. I doubt your memory is a concern; though I dont know much about intel overclocking, i dont think you'll be getting to 200fsb with it.
