- Jun 3, 2003
What's this "shimmering" everyone complains about?
I saw nothingNidhogg said:it kinda looks like what heat does to a asfalt road if you look off in the distance
of if you are out in a hot desert and the sand in the distance starts to look like water because the heat bends the light before it reaches your eyes
with shimmering as you move, the texture, the ground mostly, ahead of you starts to bend or blur kinda
here is an example, see if you can see it
http://www.abu-el-mot.de/rs/bf.avi
if you cant, grats
