Quick Memory OC Question on A8V Deluxe
dbaldus
So in my A8V Deluxe mobo BIOS rev 1017, I'm not seeing any way to actually set the speed of the memory. My question is, do I just set the SPD parameter in the BIOS to "Limit 1:1" to have my RAM run at 220mhz if my FSB is running at 220mhz (basically, I just set the FSB of the proc and then let the RAM match it if possible)? If it's as simple as that, then great. If not, how do I increase the speed on my memory to match the FSB on my proc?
Thanks!
