Quick Impressions: Gigabyte RX 5700 XT Gaming OC
Discussion in 'AMD Flavor' started by jhatfie, Sep 4, 2019.
  1. jhatfie
    jhatfie [H]ard|Gawd
    1,451
    Mar 19, 2003
    Just got my Gigabyte RX 5700 XT Gaming OC delivered today from NewEgg. Messed around about an hour to get a quick and dirty OC and did a few real quick comparisons to my Radeon VII which was lightly overclocked.
    First observations. 5700XT is getting random flickering with two monitors running at the same time, 1 monitor is fine. Did not have same problem with Radeon VII.
    +50% power limit does seem to allow a slight boost in clocks, but junction temps start to get high. +30% runs a bit cooler and not much drop in performance compared to 50. 950mhz is max I can go on memory in AB or wattman....curious how much higher it can go. No voltage adjustments either. Would love to see how undervolting does.
    I run a custom fan curve, with 55% fan set for when temps hit 70c. 90% fan at 85c. Noise is actually very similar to my Radeon VII at the same fan speed settings. Not bad, but not all that quiet either. Not surprised as both cards have what appears to be the same fan sizes.
    OC Settings:
    5700 XT : 2070 core | 950 memory +30% power limit
    Radeon VII: 1840 core | 1100 memory (this was my 24/7 daily settings with slight undervolt which gave more stable clocks)
    Tests were just the canned benchmarks in the game except Control, which I tested over a 5 minute time and used FRAPS. All settings mostly at all highest possible settings (few exceptions though like volumetric clouds and shadows usually a click below max) and 1440p.
    Radeon VII - Min | Avg
    Division 2: NA | 74
    AC Odyssey: 26 | 71
    Far Cry NewDawn: 78 | 99
    Metro Exodus: 33 | 57
    Forza Horizon 4: 91 | 105
    Control: 47 | 62
    TimeSPY: 8877 (graphics score) Although to be fair my best score was 9560 at borderline unstable OC but was on a different build.
    5700XT - Min | Avg
    Division 2: NA | 68
    AC Odyssey: 27 | 67
    Far Cry NewDawn: 77 | 96
    Forza Horizon 4: 94 | 108
    Control: 50 | 62
    TimeSPY: 9533 (graphics score) Stock score was 8585
    So with those games anyway, really pretty dang close performance. Still have some messing around to do, but I doubt there is much more there for performance unless voltage and memory controls become available for me.
    Ziontrain, c3k, N4CR and 4 others like this.
  2. harmattan
    harmattan [H]ardness Supreme
    4,239
    Feb 11, 2008
    Crazy how close 5700 XT gets to the VII at 1440p. I'd expected at 4k, however, the VII would pull ahead some.
    As for the flickering, can you try switching the cables and port connections e.g. try running a single monitor out of the second port and see if you're stick getting flickering. You could also switch your secondary monitor to your primary in Windows and see if the issue persists: if it persists on the primary monitor, it's likely a hardware issue (port or cord); if the filickering occurs on the secondary monitor, it might be software or drivers.
  3. Ready4Dis
    Ready4Dis Limp Gawd
    508
    Nov 4, 2015
    Thanks, great info. Any chance you got any power #'s between the two? Let us know if you get to undervolt, I'm still running my fury OCed and undervolted, much more efficient than factory :).
  4. jhatfie
    jhatfie [H]ard|Gawd
    1,451
    Mar 19, 2003
    I did not get any accurate power numbers, but if afterburner is accurate at all, I saw a peak of 278W with averages maybe in the 220-240W range (seems similar if I recall to my undervolted VII). Again, just eyeballed. Temps peaked at 70C and were generally 65-68C. Memory peaked at 72C, VRM 64C. Clocks jumped around, but generally averaged over 2000Mhz through most all the testing, depending on the game I was testing I'd say the average was 2020-2040mhz.
    I'd need to get more testing in though to say for sure, as above info was just from limited testing.
  5. Ready4Dis
    Ready4Dis Limp Gawd
    508
    Nov 4, 2015
    No problems, thanks for the additional info.
  6. cybereality
    cybereality [H]ardness Supreme
    4,593
    Mar 22, 2008
    The flickering is a conflict with MSI Afterburner. I have the same problem.
    In any case, you can do mostly the same things in Wattman, so just close/disable Afterburner and you should be okay until they fix it.
    c3k and Maddness like this.
  7. jhatfie
    jhatfie [H]ard|Gawd
    1,451
    Mar 19, 2003
    I was going to mention this, figured it out yesterday. Thanks for sharing though!
    Did a quick comparison with overclocked/undervolt to stock running the Metro Exodus Benchmark. First OC setting was stock power limit, +30Mhz core, 950mhz memory and 1.15v.
    OC+ setting was +30% power limit, +30mhz core, 950mhz memory, voltage 1.15v.
    Stock
    Low fps | Avg fps | Edge | Hotspot | Peak Core Speed | Peak Watts | Fan speed
    31.97 53.91 72C 98C 1916Mhz 195W (Auto Fan) <---- Right around 50-55%
    OC
    32.77 54.95 64C 87C 1960Mhz 196W (60% peak fan)
    OC+
    33.84 57.78 67C 98C 2012Mhz 227W (60% peak fan)
    OC was about 2% improvement over stock in terms of average fps
    OC+ was about 7% improvement over stock in terms of average fps.
    Increasing power limit showed power draw go up but not no real gains in fps with this specific test.
    Maddness and cybereality like this.
  8. Darth Ender
    Darth Ender Limp Gawd
    383
    Oct 11, 2018
    that's pretty much the story of the game for all amd products. There's nothing really left on the table from the rating sold. Just tons of heat produced for no significant gain. But that's not bad, the products being sold are performing very well.
    I'll have some stuff to say about how this behaves in debian probably by mid next week. I use only the open source amd drivers so it should be interesting to compare stability / performance from my current rx 480.
    cybereality likes this.
  9. jhatfie
    jhatfie [H]ard|Gawd
    1,451
    Mar 19, 2003
    Here are some teardown pic's. Looks like they did a pretty decent job. Thermal paste was not put on crazy thick and everything made decent contact. Temps did not improve when reassembling with GC Extreme. I was hoping that hot spot temps would improve a little. It is interesting how certain games heat the gpu more than others, for instance Control hammers it and gives me the highest temps, then games like Forza, even with 100% gpu are much cooler running.
    N4CR, Maddness and cybereality like this.
  10. jhatfie
    jhatfie [H]ard|Gawd
    1,451
    Mar 19, 2003
    Another observation, for some reason this specific card's idle temps are also way higher than I'd expect. Even if I manually put the fan to 30% minimum fan, when idle and doing nothing, the temp always hangs out at around 44-45C in a 21-22C room. A good amount higher than any other card I've owned. My Radeon VII was mid 30's at idle with the same fan curve. Reseating the cooler with new paste did nothing to improve the idle temps either.
  11. FlawleZ
    FlawleZ Gawd
    810
    Oct 20, 2010
    I too am surprised at how close the 5700 XT is to the Radeon VII. Here I thought there was no way it would be faster than Vega 64 before they were released. Good information here. Thanks for sharing your experience so far.
    N4CR likes this.
  12. cybereality
    4,593
    Mar 22, 2008
    Yeah the XT was a nice surprise. Especially at 1080p the performance is pretty comparable to the Radeon VII.
    1440p is still good, but once you go to 4K, the VII pulls ahead. Way better than Vega 64, though.
  13. Darth Ender
    383
    Oct 11, 2018
  14. jhatfie
    jhatfie [H]ard|Gawd
    1,451
    Mar 19, 2003
    Yeah I have reinstalled the cooler several times and temps are consistent. Even at default NOT OC'd settings with default fan curve, temps seems higher to me than I would expect. Playing Control (What seems to be one of the most gpu stressing games I have) I am seeing 81-82C core and 103-105C hot spot average. Default fan at those temps seems to be 46-47%. Cranking the fan up helps, but it starts getting noisy at 60% fan so it is the max I prefer to use for daily gaming. With default settings, except using 60% fan I am still seeing 74C core and 96C hot spot. Those temps are after at least 30 minutes of gaming compared to some of my tests earlier which were short duration and did not give enough time for full temps to be reached as it was just a few loops.
  15. jhatfie
    jhatfie [H]ard|Gawd
    1,451
    Mar 19, 2003
    Looks like my high idle temps are related to this: https://community.amd.com/thread/241665
    Confirmed my memory speed is always locked at full speed. None of the solutions mentioned worked for me.
  16. Darth Ender
    383
    Oct 11, 2018
    well, debian unstable still doesn't have support for the 5700. even building mesa git with llvm 10 and running a built 5.3-rc8 kernel still results in a failure of xorg to use the amdgpu driver and have hardware accel. Trying to use the debian built mesa 19.2-rc1 pkgs results in just deadlocks when xorg tries to use the amdgpu driver. Xorg logs dont really show much info on why, since as usual with those kind of errors, it doesn't write to the log.
    trying to use amdgpu-pro similarly failed, since, as usual, the proprietary drivers use older kernels and I'm not running an older kernel just for the driver.
    So, stuck in xorg with non-accelled vesa type drivers. Supposedly 19.2-rc2 will work, since rc1 was compiled with the wrong version of llvm but that probably wont get pushed to the server for a few days
    On the windows front, the amd drivers also suck in that OS as well. Half the games I have in that OS failed to work. Elite Dangerous just sits there with a blank screen. No Man Sky gets to the initializing screen after loading it's shaders and locks. Both of those aren't in steam.
    Tried a steam game (Conan Exiles), that worked fine. Guess i'll be crossing my fingers that Borderlands3 works well.
    All in all, i guess it's a good reminder as to why I was still running an rx480. AMD graphics drivers truly are garbage for a good 3-6 months after hardware release.
    And while Nvidia always ...and repeatedly, deserves a huge middle finger. What the hell amd. Hire some competent software engineers
  17. cybereality
    4,593
    Mar 22, 2008
    You should have no problems in Windows 10. I tried at least 10 or 15 games with no issue.
    But do make sure your are not using MSI Afterburner, RIva Tuner, etc. There is a conflict right now.
    I'd recommend a DDU safe mode uninstall, make sure to remove both AMD and Nvidia drivers in case there are left overs.
    You can also unplug the internet before the DDU uninstall to make sure Windows doesn't auto-install an old driver. Then install AMD latest before plugging back in.
  18. Darth Ender
    383
    Oct 11, 2018
    i dont use tuning tools in windows, nor do i install motherboard tools or 3rd party card drivers etc. Only amd drivers from amd before this new card and now.
    reinstalling the drivers wouldn't solve these issues since i'm not experiencing an inability to play any game that uses the same graphics api / features. Just some games are triggering lockups / freezes or are crashing when trying to render.
    It seems on the windows front, AMD has an issue with navi misbehaving when there are multiple applications attempting to use hardware accelerated calls (like chrome and a game or a game and some video player or a game and a video encoder or a game and say the microsoft gaming overlay)
    Lots of reports of issues involving that, which maybe what is occuring on my particular set of games.
  19. jbean7457
    jbean7457 Gawd
    602
    Mar 6, 2005
    I have had my Gigabyte Gaming 5700 XT for a few days now. I have experienced a BSOD at least once a night, almost entirely while browsing websites with embedded video.. usually youtube. I have had great performance in games and no instability at all while gaming, so i'm content for now and hoping the drivers get cleaned up to cut down on the BSOD issue.
    I have not done any driver cleanup using DDU but I think I might give that a shot. The fact that it has not had any issues while 5+ hours of gaming makes me think driver cleanup won't help very much, but you never know.
  20. cybereality
    4,593
    Mar 22, 2008
    DDU can absolutely still help, it takes 10 minutes and it's worth a shot in case driver files were corrupted or left over from a previous install.
  21. Darth Ender
    383
    Oct 11, 2018
    So a couple games stopped crashing once I manually deleted the game's graphics/display settings file.
    One downside to modern games behavior in no longer having a 2d ui to config graphics settings prior to getting into the actual game I guess.
    Should be able to test Linux support by this weekend. Debian hasn't yet rebuilt Mesa and pushed to the servers.
    Power usage currently in Linux vs windows is significantly higher as it seems in Linux the system is not dropping to the lowest pstates or sleeping cores as much as windows seems to
  22. jbean7457
    jbean7457 Gawd
    602
    Mar 6, 2005
    Ok I ran DDU in safemode and ran it twice to clean out any nvidia drivers and amd. Unplugged ethernet cable then installed the latest 9/10/19 drivers from AMD. I'll report back in a few days if I notice an improvement in BSODs.
    cybereality and Maddness like this.
  23. cybereality
    4,593
    Mar 22, 2008
    Awesome! DDU doesn't always work, but it has saved me several times from strange issues.
    Maddness likes this.
  24. Darth Ender
    383
    Oct 11, 2018
    dx12 badass quality setting 1080p ....benchmark in borderlands 3 seems to average out around 74fps. Though I'm also using triple buffering to reduce frame tearing since I dont have a freesync monitor.
    gpu temps stay in the mid 70's according to the wattman overlay. fan speed is in the high 1900 rpms. ambient temp was 76F.
    Pretty happy with the performance so far.
    Though, i think the dx12 driver is glitching in certain lighting glow effects - more of an issue with the beta quality of that rendering engine than the card though.
  25. jbean7457
    jbean7457 Gawd
    602
    Mar 6, 2005
    So I still got BSOD at least once a night with my Gigabyte 5700xt, even after cleaning everything out and running DDU in safemode. So I saw a few nights later 19.9.2 came out that said it addresses the BSOD issues with video playback, so I installed them. Glad to report that it's been at least 3 days and not a single crash since the update. Anybody else have luck with the 19.9.2 drivers?
  26. Darth Ender
    383
    Oct 11, 2018
    I only had issues with lockups during some games where they configure graphics settings within the 3d ui of the game and do not auto reset when the previous card is no longer detected. Never any bsod's. Deleting the config files manually to reset the default fixed those.
    Also, I was already using an amd card before. I never clean install. Been fine for years, still fine now with the current drivers.
    My computer is always on, so I'd notice if it decided to crash on its own just sitting in Windows or Linux.
