Quick Help Once again Required ! ! !
Ok so i just received my bridged usb network leads in the post this morning. When i was trying to install the software on my laptop (this computer), it gave me a msg saying that there was insifficent memory to process the comand.
The system requiremeants for the cable:
Intel Pentium 1Ghz or faster PC
128 MB RAM or higher
USB Port (2.0 port required for Hi-Speed transfer)
Windows Vista and XP
This is the Exact cable i have and i bought 2 for networking.
http://www.tekheads.co.uk/product/1.8M-USB-Network-Bridge-Data-Link-Cable_19336.html
My Laptop Specs
AMD Turion x2 ultra 64 2.2 Ghz
4 Gig RAM
500 Gb HDD
ATI Mobility Radeon HD 4570
USB 2.0
Vista Ultimate
Now i find this very odd not just because its not installing but because having received the cables today the packaging has no mention of networking. It just says Vista USB Link Adapter. It mentions the windows easy transfer utility but thats it.
Second Question
Is it possible to boot and run a computer over a network if the computer dosent have a hard drive? If so how do i go about doing this ?
1) Was the software included with the cable? Did you try using it without the included software and just running the windows util?
2) Use a LiveCD, like Ubuntu/Knoppix/UBCD4Win/BartPE.
nope i havent tried running it without the software as i only have one operational computer at the moment. However the software was included.
second
is there any way to do it without a live boot os ?
i was hopping to network boot it with windows
