vsboxerboy
- Oct 17, 2005
Two question:
1. When I open a new tab, it displays a blindingly bright (when the lights are off). How can I have this open a black page instead of a white one.
- I have greasemonkey and darken installed already, but this doesn't cut the mustard. This isn't a huge issue, just figured I would ask.
2. Is it possible to do something in the about:config to disable the vertical scroll bars? Seems a bit redundant when I just use the trackpad to scroll.
In case you were wondering, this is my netbook which I am trying to maximize screen real estate for.
Thanks!
Thanks!
