Just need a replacement for my 60mm case fan that gave up the ghost. 3-pin connector, with speed sensor if possible. I'm looking for something in the 20ish CFM range and as quiet as possible.
I saw the reviews and I'm lookijng at the new Panaflo 60mm Low-speed ones with speed sensors. Any other ideas?
Also, I'd like to link a pair of these up on the same 3-pin connector, is that possible? bad idea? how do I make sure the speed sensor will respond correctly?
