Later today I'll be setting up a computer with an nforce2 igp board (biostar) and will be using the integrated video. Do I need to install the forceware 56.whatever drivers for the GPU or will the nvidia nforce2 platform drivers cover it?
I've found the best results using the 44.03 drivers on my 2 IGP boards.
I run:
2 x Shuttle MN31Ns
2500+ Barton @180FSB
2 x 256mb Crucial PC2700 @6-2-2-2.5
128mb AGP buffer and aperture
Disable both spread spectrums, cachables and 8X support
Enable fastwrites
OC IGP with Riva Tuner to 275 on core
Remove NB sink, lap to 1000grit & reapply with thermal compound and add a fan if it doesn't have one.
I can hit ~6K in 3DMark with these settings, plays BF1942 @1024 X 768 x 32bit with no problems.
Makes a sweet low-budget micro LAN rig.
