Quick-disconnects
chinabean
OK I've had my water cooling setup for a while now and I've never had a problem with connecting/disconnecting the tubing because its been in 1 spot the whole time. Now i need to move it and want to add quick connectors to make transportation easier in the future. I have 7/16" ID (5/8" OD) tubing and I cant find any quick connectors for it. I basically want the tubing to plug into a pci slot and then quick connects to go out to the external radiator.
Does anyone know of any product like this?
i noticed that they all seem to have a thread on the coupling body, how does that attach to the tubing?
Read through all the discriptions, they offer plenty that have barb fittings in every size.
If you're looking at "No Leak" quik connects, you might want to consider going up a size or so because of the additional flow resistance of the "No Leak" feature.
