Quick custom resolution question.
Hi.
I'd like to change from my native resolution on my GT330M laptop of 1366xXXX to my good ole 1680xXXX one.
Problem is, I can't find ANYWHERE how to set a custom resolution on either Windows OR the nvidia control panel.
Any help available? Is this even possible?
Edit: I don't mind keeping the 16:9, I just prefer the 8:5/16:10. If 1600x900 is possible, I'd take it too.
If your native resolution is 1366x768 (?), why are you trying to set it to a higher resolution? Aside from not working, it will just make everything look terrible. What are you trying to accomplish?
Some systems are setup to allow you to set a higher-res than the display supports and then the monitor is still doing 1:1, but it lets you scroll around your desktop with your mouse at the edge of the screen.
I'm not sure if that's what he's talking about or not, he's phrased it such that it makes little sense.
Seems he wants to run his 1366x768 laptop screen at a higher resolution? If that's the case, it's obviously impossible.
