chinkecheese
- Oct 23, 2007
I'm planning on buying one of these motherboards.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138320
or
http://www.microcenter.com/single_product_results.phtml?product_id=0371775
or
http://www.microcenter.com/single_product_results.phtml?product_id=0374835
or
http://www.microcenter.com/single_product_results.phtml?product_id=0366193
My question is, can the biostar run a current-gen crossfire solution? i,e two 6950s?
it mentions that it has a pci express 2.0 x16 (x2 slow, one of which runs electrically at 4x). I'm not entirely sure what the 4x means.
Also, since neither card has pci 3.0, will it run the new HD7000? I read that it's pci 3.0 compliant, but is it a requirement?
thanks so much..
p.s. which would you recommend?
Biostar or Asus? ($49 or $69)
Gigabyte or MSI ($89 or $79)
or
or
or
thanks so much..
