ziphnor said:How are the weeks counted, starting at week one on January 2006? Because then it confuses me that a chip packaged 10/06/06 should be one of the newest ones. At first i thought i might have misread the label, but i double checked and it IS L632. So i guess the week count is based on something else?
chrisf6969 said:Say week 32 / 4 = approx 8 months. So it was made in August some time, but its a long process from a large wafer of silicon, diced up to squares, putting it on the package, various testing at various stages, binning, to packaging in Sept/Oct.
Usually the voltage under load drops by about .05 its called vdroop. Look it up, its a very well known issue. Thats why you see that drop.
As for the temps, Core Temp usually shows about 10C+ higher than other windows temperature readings. Like SpeedFan, Asus Probe, etc. Are you sure its showing 10C lower?
ziphnor said:Im 100% sure, though it varies from 5C to 12C higher in PC-Probe. At my current speed CoreTemp says 59C under load(i think i put too much thermal paste onbut Asus PC-Probe is at 63-65C.
ziphnor said:Is it also normal that vCore is much lower than set in the BIOS in general?
ziphnor said:I suppose something is fishy then, because i get ~0.1V difference between BIOS and windows. My PSU (SeaSonic 430W) is supposed to be pretty decent so i dont think thats what causing the problem.
However, when i start in at 3.4-3.5Ghz with a reading of 1.44, the initial reading is much lower in CPU-Z, around 1.25 and then goes up to 1.44 when ORTHOS starts, i guess it must be some automatic voltage adjustment at work or is my computer completely crazy?
Btw, i also managed to boot at 3.6Ghz, which gives and initial vCore of 1.2-1.3 as well but ORTHOS gives an error immediatly.
ziphnor said:Hmm, i always seem to get the same vcore reported by Asus PC-Probe and CPU-Z(though i didnt check for the very high voltage).
I will check it to make sure. If both PC probe and CPU-Z reports the same then something fishy is going on.
ziphnor said:I dont get this BIOS. It keeps settings strange memory timings and no matter what i set manually it wont boot (i even tried all timings at max). To test the RAM i booted at 400x8 = 3.2 with timings set by SPD in the BIOS. This yields the following:
http://img64.imageshack.us/my.php?image=timingswc6.png
That is, CPU-Z says the SPD for 400Mhz is 5-5-5-18 but its set to 5-6-6-18 !?
chrisf6969 said:I see thats what the stick in Slot # 1 says, but did you check the stick of ram in Slot # 3.... use the drop down menu. I've seen it happen MANY times before when a supposed "pair" of ram are programmed differently. So they BIOS uses the slower timings.
Maybe Asus's BIOS is applying "the formula" normally you take your first 3 numbers and they should add up to the last #. So inversely they're taking the 2 most important settings CAS & TRAS & filling in the middle 2 #'s.
Since A-Data programmed Cas 5 & the Tras = 18, its filling in the other two numbers as 6's.
