Quick connection?
magda
I bought these quick connect hose fitting
Are those too much restriction?
Thoughts,l?
First time using these connectors.
Are those worth it? Or they cause too much flow restriction?
Koolance worked on our RD30 system at full flow! I did have some weeping issues with some of the first gen fittings (from 2011) but that was fixed in newer versions.
