Hi all, I just discovered my Swiftech MCP655 pump wont fit in my PC case because of the 8800 GTS is in the way. Ive decided to buy a barebone case and install all the watercooling parts in it like the pump , radiator and res and just have the inlet and outlet tubes running from the barebone to my PC. I want to put 2 quick connector fittings on the loop between the barebone and PC so if I need to get inside my PC I can just disconnect the two. Problem is I haven't been able to find any to fit my 3/8 ID / 5/8 OD tube. Can anyone recommend a site where I can get some in the UK if possible.
