Quick chipset q
Deep88 said:
VIA K8T800 Pro
vs.
nforce3
wich one and why?
Both of them are athlon platforms, so they are both rather unstable, but
VIA is more-so plagued, expecially the one you listed, the NF3 is more stable, more feature-rich and can overclock further...
Go NF3
WTF?
nForce3 is targeted at "enthusiasts" aka people that have some vague idea what goes on in their computer and presumably care about how efficiantly it works. That's what the marketing people label it anyway. VIA's targeted at like office computers where they need 200 and don't give a crap what's in it, or at someone's granny's computer where they're just going to use it for email and AOL or something.
ashmedai said:
WTF?
What does that have to do with anything :confused:
It's better than the "Athlons are unstable, and ones on VIA are more unstable" line.
I've you've worked with the Asus A8V Deluxe (K8T800 Pro) at all before, you'll find that it is a very stable board... not exactly the fastest or the strongest overclocker, but it is a very well-rounded board. Passive cooling all around to me is a big bonus for those lower-maintenance rigs.
Yup. Contrary to what ScHpAnKy said, VIA is perfectly stable. nForce is just targeted at people who give a crap beyond stable. And if he and Peach are having so much trouble getting their Athlon-based systems to be stable, I'd tend to suspect user error as it's the leading cause of computer malfunctions.
I disagree with that. nForce boards (2/3/4) tend to take a little more active maintenance from the user in order to run at it's peak.
How? If thats true then explain how my fileserver has been running for nearly 2 years with no more maintainence than apt-get upgrade and teh occasional can of air?
Even when true, that doesn't invalidate my point. VIA is a good choice when you want the thing to sit there and be stable.
what kind of maintenance exactly?
Not speaking from experience, but just from what I saw... when the MSI K8N Neo2 just came out, there were a lot of issues with the board. Dropping sound functionality, dropping ethernet functionality, etc. Not really sure if it was the MSI board doing it, or the nF3 chip.
Blah, kind of hard to explain :p
Not necessarily true, while you may have seen two or three of these boards, I have sold and had to repair systems daily that used this specific motherboard... not only that other boards built specifically around this chipset.
All 939 boards are unstable, it's simply put as that. I've run every board the market has to offer and the Neo 2 happened to be the best of the the NF3/VIA series, but that doesn't say much and it has it's own set of quirks (such as the inability to change HTT multiplier by simply pressing the "Return/Enter" button and manually setting it)
How are you defining unstable? Most systems that can handle an overnight run of Memtest86+ followed by another of Prime95 tend to be pretty stable in practice.
_Korruption_ said:
Quirky is a good word to describe the K8N Neo2... :p
That's why I wish DFI would get off their ass and release theirs already...last I heard is June/July. Actually since I already have my rig, I'd rather they just make me more BIOS updates and such. But still. ^_^
Epox is a pretty good alternative. More stable & can still do 300x9 or better.
Does the PC crash? It's unstable. I've run several different setups on different chipsets with different types of memory, video cards, power supplies... hell, even down to the hard drives. Not one configuration didn't crash after being up for an extended period of time. I leave folding running 24/7 on my desktop to test stability sometimes, but for certain setups I just let Prime95 run because memtest only tests for memory instability.
I'm also still waiting for DFI's approach into the market, but I fear for it.
If the new DFI board is anything as picky as the DFI LanParty Ultra II B was, then I'm in for even more hell, if not, things will begin shaping up for the 939 department that doesn't want to make the "upgrade" to PCI-E. :cool:
I figure it's basically an Ultra-D with AGP instead. I haven't seen much to contradict this yet and what I have seen would tend to support it.
That would certainly be ideal, I still don't see they don't run NF4 with an AGP port that goes through the PCI-Express bus as ECS does
Probably because it's to add a bunch of extra circuitry to allow that instead of just using a chipset that can already do it. And I haven't seen any PCI-E > AGP tech implimented yet that didn't have major issues.
