legendz411
- Jul 3, 2006
Moderate gaming, hi-def media consumption
I have this build at about $560. No real budget, trying to maximize price/preformance
Jacksonville/Florida
Just checking to see if my mobo choice is the best, amogst otherthings
keyboard/mouse
6) Will you be overclocking?
i mean, probably not... but.....
7) 7) What is the max resolution of your monitor? What size is it?
Will be purchasing a 20" moniter, so 16x9
Next couple weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
Int. GFX to utilize built in gfx in the event of gfx card failure
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Handled
keyboard/mouse
Next couple weeks
Handled
- http://www.newegg.com/Product/Product.aspx?Item=N82E16814121474 // Radeon 6770
- http://www.newegg.com/Product/Product.aspx?Item=N82E16813138332 //
BIOSTAR H61MGC Intel H61 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115077 // i3-2120
- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231422 // 8gb ram stikk
- http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767 // 500gb hdd
- http://www.newegg.com/Product/Product.aspx?Item=N82E16817256061 500watt PSU
