Yes and yes but you have to download the Windows/Dos program and put it on a bootable floppy that DOES NOT have Himem.sys or Emm386.comGary King said:So I leave it overnight eh?
Can I run the program from a floppy?
Good point and I totally left that off my list. The BIOS setting can of course introduce errors.ashmedai said:Failure often means you just need to adjust the settings in the BIOS...although if it does it at stock speed and the correct settings it's most likely RMA time.
I just run it through about end of test 5 when I'm tweaking, then overnight when I think it's done.
