quick air flow mod for XPC
gave the new X800XTPE some fresh air:
gratuitous front shot:
rear end air flow mod:
FYI - the lining around the vid card fan window is the same material that you would use to build a window screen. its the stuff you use to hold the screen material in place. i ordered some of that window molding, but the screen material is much more flexible. when i got the molding i realized i would not be able to make the 2 bottom corners without cutting it in an odd way.
