I just installed a S1 on my 8800GT yesterday and I must say the temperature performance is as good as reported here in the forums. However, I finally gave up on installing those @#$! plastic clips completely. It seemed like no matter where I installed the clips (and there are precious few places where they seem to fit correctly) I would get a funky bend in my card. Releasing the clips removed the bend from the card, so I finally just went without the clips. My question is: are these clips really necessary? It seems like the majority of the weight with the S1 is on the side with the actual GPU plate. I can't see that the mounting screws aren't enough to properly mount the S1.
Dave
Dave
