Quick ? about OC'ing A64 cpu's...
loft
Wondering... when OC'ing an amd a64 san diego... I've read that HT Link should not exceed 1000. What I'm curious about, is, should we try to get HT Link as close as possible to 1000 while keeping the bus speed at 1:1 with the ram frequency?
i've read its not very important to get it close to 1000, if i remember right there isn't much benefit over 750-800mhz. What motherboard do you have, i know some motherboards can run a pretty high HT bus, case in point mine runs at 1200 stable (A8N32-SLI Dlx).
ht won't get saturated. like mentioned, if you can keep it between 800 and 1000, you're fine.
