Quick 20 Pin PSU Question
GoodOmens
I have a dfi ultra-d comming in tomorrow and it has the new atx 2.0 plug.
My g-card is the BFG 6600GT OC which does not have a power connector on it.
My question is this, will plugging my 20 pin into the board with nothing plugged in to the pci-e still power my card? Or will I need a 20->24 pin adapter?
What I've read has slightly confused me as it was slanted towards already having the power connector on the card so there was no need for the extra 4 pins.
You will need a 20 to 24 pin adapter. Ideally you should upgrade your PS to a 2.0 compliant model as the 2.0 shifts the power usage from 3.3V toward more 12V usage (see PS forums). With this mentioned, you may run into issues with regard to stability using your older 1.2 or 1.3 standard PS.
Good luck.
I have a enermax thats rated at 33wats on the 12 volt rail ... I really dont want to scrap it.
Its the Enermax EG465P-VE .
Yea I bit the bullet and I am getting the OCZ Modstream 450.
I'll sell it down the road when dual cores hit their first price drops and I upgrade again ... but that should be fine for my current set up (And it was $60 at monarch with mail in rebate).
