Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I havent built a computer in more than 5 years so im really out of the loop, just got my 4870 and im cluessess if I should use both 6 pin power connectors or can I just use one 6 pin power connector?
Not trying to be a smart ass or anything, I'm actually curious. Aren't there instructions with the card that the describe the installation process? Like I said, just a question. Thanks!
