Questions/Suggestions needed for Ultimate Gaming Rig!!!
Ok, maybe not the ultimate but about the best tech I could come up with.
I am currently running a P4 2.4C at 3.1ghz w/a BFG 6800 OC and am I looking to upgrade... this upgrade needs to last and run everything coming out for the next 2 years or so. Assuming no huge leaps in technology here is the shopping list for now:
Thermaltake Armor Full Tower Case
Enermax Noisteaker 600W PSU
DFI Lan Party NForce4 SLI-DR
AMD Athlon 64 X2 4800+
2 GB DDR (2 pcs 1GB) PC-3200 (400) OCZ Dual Channel Platinum
Thermalright XP-120
2 BFG Geforce 7800 GTXs
2 Western Digital 74 GB SATA 10K Raptor (WD740GD)
NEC ND-3540A 16X Dual Layer DVD±RW
Mitsumi Floppy 7-in-1 USB Card Reader/Smart Media Internal Drive
Ok, so would you go with a different memory? I can't get the Revision 2 platinum in the 2GB set -- anyone know of anything with better timings that comes in dual channel 2gb?
As I understand it that when OCing this new AMD chip that it is only the "Processor Bus" which is getting OC'd and not the the memory or anything else?
Would you stick with XP Pro or go for the XP 64bit operating system?
Any suggestions or comments would be greatly appreciated. Thanks!
I system look good though i personally dont like the case if you want a full tower maybe look into the Coolermaster Stacker ive heard alot of good things about it.
Stick with XP Pro there isnt really a big advantage moving to XP64 plus i think you can get a free upgrade to XP64 later (can anyone else confirm this) plus you have to have all 64 bit drivers which can be hard to come by.
Go with an X2 and one 7800 for now.
There's no reason to spend 1K on a processor, especially when it's only 200MHZ faster, and SLI isn't necessary at the moment. A single 7800 will serve your needs just fine, so leave room to upgrade later when they come down in price.
