Pycnopodia
- Sep 2, 2010
I purchased a new beefy computer to play World of Warcraft but made a mistake in picking the video card. I bought Radeon 5970 but are only able to utilize one of the GPU (in wow) and Im severely bottlenecked by this as Innerspace (the app I use to render wow) does not work with Crossfire enabled and 5970 cant disable this (disabling AI doesnt disable the internal Crossfire).
I want to add in a second card (Radeon 5850) and use this to help render some instances of Warcraft. My GPU usage is 80% for one instance of WoW with max graphics and around 20% when graphics are set to a low level so according to my estimations I will be using around 80% of both cards resources if I have 5970+5850 (while one GPU on 5970 is inactive due to the liimiation).
My questions are as follows:
1. Can I disable the Trifire and run games on only the 5970`s Crossfire for compability? (In case Trifire works poorly in games).
2. I have 3 monitors in landscape mode connected to my 5970, if I add in a 5850 I will connect the rightmost monitor to both cards (5970 by DVI and 5850 by HDMI) and a projector to just the 5850 (by DVI).
Does this mean I need to disable Eyefinity and play WoW on dual screen in order to use both graphics cards?
3. Ill only be using tops 3 monitors at the same time but will having the projector conneccted to the 5850 let me switch between Eyefinity 3x1 and single monitor+big screen through tinkering in Catalyst Control Center? I want to be able to switch between using monitors and the big screen without moving around cables to different outputs
Im also considering just selling my 5970 and buying two new 5850`s or something, that is guaranteed to work and there wont be any "HAH GOTCHA" when installing it like with my 5970 performing worse then a single 5870 in wow.
This has been troubling me for a while as its kinda lame to have a brand new computer perform like some old outdated hardware and having to reduce graphics and resolution, the solution to this annoyance doesnt cost too much I just dont want to be cought in an endless cycle of replacing hardware with new hardware that also dont work as intended/planned.
Please help me
Please help me
