roadtonowhere08
- Nov 17, 2003
I have a few questions regarding Intel's 64GB X25-E. I understand that it uses SLC flash, which is much better for longevity than MLC. I also understand that it has better write speeds than the X25-M series that use MLC flash. I am considering one as an OS/Application drive, but I need to know a few things about it.
There are two things I care about most:
1. Reliability/Longevity
2. Consistent speed after weeks/months of use
Here is my plan:
1. Use an X25-E as an OS/Application drive and turn off any prefetch/caching/indexing services while offloading the page file to my Velociraptor. All music editing and encoding will take place on the Velociraptor to cut down on writes to the SSD.
2. All games, music, and movies go on WD Black drives
Here are my questions:
1. Is the X25-E series affected by declining performance over time as the X25-M series has been reported to be?
2. Even though the SLC flash can theoretically be re-written over 100,000 times typically, would using one as an OS/Application drive give me as long of a lifespan as say a 15k RPM SAS drive?
3. SLC does not need to be prepped to have the same consistent write speed over time, and using the TRIM command only applies to MLC flash, correct?
Another option is to get a 15k.2 Savvio with a SAS controller to bring me to the same price as the Intel SSD. I would lose the snappy speed but I could not worry about the finite writes issue and encode and edit all I want. SAS is a proven reliable technology that one could beat on every day and not worry about longevity, but apparently SLC flash is pretty reliable as well.
Keeping in mind that reliability/longevity as well as consistent speed over time is of utmost importance to me, which path would you choose and why? Each path is expensive, so I want it to last at least 5 years of heavy use...
Here is my plan:
