Bear with me I usually deal with older computers that have no need for more than 1 fan. I am building a new system (Q6600, 8800GT, nice corsair psu, CoolerMaster 690, ABIT IP35V, and Thermalright Ultima-90). The CM 690 comes with 3 120mm fans, and they have a 3 or 4 pin connector plugged into a molex adaptor. The MOBO has 1 cpu fan plug, 2 auxfan plugs and 1 sysfan plug. I don't know the difference between the aux fan or sys fan, but that isnt a major problem. The CM 690 has 2 intake 120mm fans (i am using them for intake), 1 120mm intake fan at the front, 1 120mm intake at the bottom next to the psu, 1 120mm exhaust by the CPU and there are 2 140mm exhaust at the top. That seems like a lot of fans to me. Is there a way to daisy chain them (for instance the 2 in the side panel and the 2 140mm at the top). I have no knowledge of the benefits that the 3 or 4 pin plug has, i am guessing it is for adjustable speed or something. I was wondering what you guys do? At the moment I only have 3 fans, and was wondering if you guys could help with advice for fans also. I don't want it to sound like a jet engine but on the other hand in the summer it gets very hot (southern california desert) so I have to keep that in mind.
I don't know if its necessary to replace the 3 fans that it comes with, but I need advice for:
2 140 mm fans for the top exhaust
1 120mm cpu fan for the Ultima-90 heat sink
1 120mm fan for the side panel (intake - it already comes with 1)
1 120mm for the bottom intake
This is my first time building a computer with this many fans so all input is welcomed. Thank you.
