Questions re: USB On the Go
mewa
Has anyone actually get it to work on the smartphone (Android 3.1+), for simple tasks requiring connecting moving data from on device to another?
I have seen on YouTube:
- Backing up DSLR to HDD, load movies from HDD
- Plug in keyboard/mouse for office works
But wondered how far can the OTG go:
- Connect to desk monitor/Projector: Through MHL-USB Adapter over HDMI. Not sure with a USB-DVI Adapter
- Printer: http://www.youtube.com/watch?v=m-8bnejng3Y; You also need the App PrinterShare, Select USB Printer; Print Directy, or Send to Printer. This way you will be able to stay on Internet while printing.
- Scanner:Not sure
- DVD burner: No, except the DVD Drive supports Android devices (converts to FAT32) and it would be read-only.
- Ethernet connection possible? for faster uploads
- Any other really good uses? basically eliminate the need for the ultrabook
For power draw, I am ready to bring a powered USB hub with me. But not sure about the driver or native supports and if I would have to re-buy many of the peripherals to make it work.
If this is doable, I could forgo refreshing and carrying the laptop, or the need for Surface Pro, just carry a super phone and go all open source...Any input is appreciated. Thanks.
couple notes about usb OTG: it can only deliver 100mA of power.
I've personally plugged flash drives and a keyboard into my phone without any issues.
anything outside of usb storage or HIDs likely won't work. (HID == Human Interface Device I think, basically mouse, keyboard, gamepads)
note this is all dependant on if the device in question supports usb OTG, Some don't. (much to my dismay I discovered this about my tablet only after I purchased it...)
I use USB To Go with my Galaxy S4 Active without any noticeable issues but I'm not trying to turn my smartphone into a full blown PC-experience ala Ubuntu Touch or something similar. I have an MHL to USB adapter and that works just fine. I can (and have for testing purposes) attached that do my Belkin 7-port powered hub and attached:
- a USB mouse
- a USB keyboard
- a USB hard drive (250GB)
- a USB Flash drive (8GB)
all at the same time and all of it was recognized without issues and all of it functional at the same time, but realize those devices were plugged into the powered hub which was then attached to the MHL to USB adapter since as already noted the microUSB port on the smartphone just can't output a lot of juice, especially when it's running strictly on battery power. And yes when it was plugged into the hub it was charging as well, pulling juice from the hub itself.
Now if I just had a DLNA ready monitor of some kind I could output a display signal and voila, a smartphone/PC in my hand, so to speak, maybe I could get one of those little USB displays and have some luck with that, who knows.
I really hope that soon some manufacturer realizes all this potential and finally makes a smartphone with the proper docking pins on the side ala the BlackBerry PlayBook or the Samsung Galaxy Nexus that uses pogo-pins on a dock so we don't end up wearing out our damned microUSB ports so often. It's kinda stupid that it's taking so long to do this, really.
here is a link to another forum that has links to all the products you'll need if your device isn't usb otg compatible. I can confirm this method works i have used a mouse, keyboard, usb drive, hard drive, on an hp touchpad using this. works best withthis from google play
