Questions on Which Stand up desk frame to get?
AthlonXP
As the title says, I have 2 butcher block tables right now that I want to replace the desk legs with a desk frame. The Blocks are 48 inches wide and 30 inches deep ( the block is 1.75 inches thick). I was looking to get 2 and ideally would like the height to start around 25-26 inches and go up higher.
K, i can chime in on this one.
Did a bunch of research over black friday as many were on sale. You got your cheap Ikea ones, single motor, wobbly, then you got your high end ones that are $1k +..
I settled on the Flexispot E7 Plus - why? 4 legs, better stability, I have 4 monitors, needed the weight support (quad monitor arm alone is a beast in weight)
Just got it set up (3 monitors) and so far solid. Bought an Ikea veneer table top for it, perfect size.
It is smooth as butter when going up and down, goes plenty high, I am 6' 4" and have it at 45.7" right now standing.
it is still on sale for $599 (US) Canada it is cheaper...
https://www.flexispot.com/flexispot-4-leg-standing-desk-e7plus
