- Dec 5, 2010
So i have a few questions on this one,especially the reference card:
1.Is the reference really loud?Because i got used to non-ref cards for quite some times and i wonder if the infamous vacuum-cleaner noise (on the HD4870) still exists in the HD6950 ref or not.
2.I'm running only on the 21.5" 1920x1080 monitor and not planning on Eyefinity,so would the 2GB version makes any difference from the 1GB version?Beside the higher level of AA which i don't usually use.
3.It's pretty late since the release of the HD6950,can i still unlock the shaders on the reference version if i can find one?
Thanks everybody in advance.
