questions on system performance 2 SSD's RAID 0 or no
Xenozx
Ok, so I have 2 512 OCZ triton 180's. Currently I have windows installed on 1, and i install all my videogames on the other.
I have to reinstall windows, and I was thinking of running the 2 drives in RAID-0.
At that point i now only have 1 drive as far as windows is concerned, although almost double the speed.
Would the raid setup net me better overall system and gaming load times, or am i better off keeping them separate?
when you do the windows cache thing, is it better when its on a separate disk, or if you do raid-0 does it realy not matter having OS and cache on the same drive or raid?
Don't bother caching if everything is on SSDs. If you're talking about prefetch though, leave it alone.
For general gaming usage, RAID-0 will only help a very limited number of scenarios, primarily ones where there are large maps to be loaded. Otherwise, it does not help performance, and in certain scenarios can hurt random performance.
RAID 1 also accelerate reading speed as RAID 0 + data is protected from a disk failure...
without RAID: 498 MB/s
with RAID 1: 938 MB/s
I do not recommend RAID 0...
