Questions on SLI improvements
jokerx225
Hey guys i havent been reading up on SLI in a while since i never went and bought a 2nd 7800GTX but now i will be buying a 2nd one and i wanted to know if you are able to play on a widescreen with Sli enabled? Also can you have HD enabled while on SLI. Im not sure if these problems were fixed as i remember SLI had alot of bumps when it first came out. Is there any problems that i should know about?
The WS stuff is fixed with the 8x.xx drivers... but the game has to support it for it to really work well... not sure about HD... also - you can buy a different brand 7800GTX 256mb to run your current one with in SLI.. the mixing and matching of different brand (NOT model) cards works very well with the 8x.xx driver also. Have fun!!
sac_tagg said:
Uhhh...you do realize that you don't have an SLI motherboard or power supply, right?
Ultra-D can be easily modified to be SLi (DFI use the same PCB for the same range of boards or at least this was the case here) and hence the 'converter from asus' comment next to it (as normally the connector comes with the mobo, ultra-d isn't officially sli so it doesn't come with one)
yes - an SLI bridge will need to be tracked down... well, for optimal SLI performance that is... but it will work sans bridge also... with the 8x.xx drivers.
