Questions on Seagate Barracuda XT RAID Capabilities
jahjahwarrior
I've been trying to pick a suitable 2TB drive to make up my yet to be decided RAID 5 or 6 hardware array. I've been going back and forth between the Barracuda XT and the Western Digital RE4 2TB drives.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148506&Tpk=barracuda xt
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136579&cm_re=re4-_-22-136-579-_-Product
They rate pretty closely on tests run by Toms Hardware. The big difference is price ($90-$100). Seagate being the cheaper. I know with RAIDs it's important to not use consumer drives because they usually don't have a TLER feature. I know for sure the RE4 has this feature. However, when looking at the Seagate product page, all they say is "Desktop RAID" is a best-fit application:
http://www.seagate.com/ww/v/index.j...ale=en-US&reqPage=Support#tTabContentOverview
I'm not quite sure how to interpret "Desktop RAID". I'm going to guess that it means RAIDs 0 and 1. Does anybody have a hunch or has successfully used the Barracuda XT 2TB drives in a RAID scheme other than 0 or 1 (which is all I've found reference to when searching google)?
Desktop raid would mean raid 0 or 1 meaning that the drive does not have TLER (or whatever seagate calls it). You do not need TLER for raid 0 or 1.
