I've recently put together a water cooling loop for my computer. This is my first attempt at this and I'm looking for some areas I might be able to improve.
My temps don't seem to be as good as I was hoping.
Parts...
Swiftech MCR320
Swiftech MCP655-B
Swiftech MicroRes
Swiftech GTZ
Koolance 487X2 Vid
1/2 ID tubing
3x Antec Tricool 120mm fans
Cooling...
Q9550 at 3.6GHz with 1.38v (BIOS)
4870X2 at 850/950MHz
Order...
Pump, CPU, GPU, Radiator, Res
It cools everything well enough, but I need to run my fans at medium speed, otherwise things heat up quite a bit on low.
Should I move my radiator ahead of the CPU and GPU or between the CPU and GPU? Would adding a single MCP120 make a noticeable difference?
Are the fans I am using okay. I have Yate Loon low and medium speed fans laying around. I use the Antecs because of the easily adjustable speed.
Parts...
Swiftech MCR320
Swiftech MCP655-B
Swiftech MicroRes
Swiftech GTZ
Koolance 487X2 Vid
1/2 ID tubing
Cooling...
Order...
