I can't seem to find the search and after browsing numerous threads I don't seem to have the answer. So would owners of this LCD please chime in on these questions?
This is for the LCD2490wuxi
1. Does this model support 1080i as output from a hdtv receiver, and 1080p as from a blu-ray player? both through dvi and vga?
2. Is there 1:1 pixel mapping mode in every input resolution and in both dvi and vga?
3. Does this monitor emit any noise whatsoever, like buzzing of high pitched sounds?
4. How does HD content look on this monitor through blu-ray, hd-dvd, or OTA HD. Since it has a 72% NTSC color gamut will it look worse than a dedicated HDTV?
5. What is the measured lag on this monitor? I can't seem to find a reliable answer (measured numbers) rather than just feel.
6. Is there any disadvantage of this monitor compared to something like the samsung 245t? In any aspect, no matter how slight.
7. Is the spectraviewII kit worth it? Or is it better to get just the spectraview II software and use another colorimeter? Is the colorimeter in the kit a very good and accurate one?
Thanks for any input!
