Questions on fans
TheBear
he Question is do the fan you install run at maximum rpm? or do you need the fan controllers to put it at maximum speed.
They run at Max. A fan control would be used to slow it down/reduce noise. Typically you buy fan controls if you want to slow down your fans so that you get less noise coming from them
