I currently have a P55 motherboard. It has 6 SATA II slots, raid compatible. Right now, the slots are being used as:
Slot 0: CD/DVD drive
Slot 1: 500 GB HDD (array 1)
Slot 2: 500 GB HDD (array 1)
Slot 3: 1.5 TB HDD (arrays 2,3)
Slot 4: 1.5 TB HDD (arrays 2,3)
Slot 5: Empty
Array 1: RAID 1 (contains my OS)
Array 2: RAID 1 (50 GB)
Array 3: RAID 0 (whatever's left, around 2.6 TB)
Now, I want to get a bit more storage. I have bays left in my case so that's not an issue. However, I only have one empty slot, and I have a RAID 0+1 array that I'm starting to regret. Preferably, I'd like to set up a big RAID 5 array.
One possibility is to buy 3 more 1.5 TB drives (roughly $300 total) and replace the whole mess with a big RAID 5 array.
I'd like to do this without losing any data though. I have enough space on the big RAID 0 array to fit the contents of the array in slots 1 and 2.
My plan is to copy the contents of array 1 onto array 3, and then remove the 500 GB drives from my computer. Then, I could set up a RAID 5 array with 3 hard drives (slots 1, 2, 5) and install my OS. Then my two arrays would have roughly the same amount of storage space, so I could copy the files from the old RAID 0 array onto the new RAID 5 array. Finally, I could disband the RAID arrays in slots 3 and 4 and add those hard drives to my RAID 5 array, so I end up with a big RAID 5 array with my OS, data, and 6 TB of advertised space (about 5.4 TB actual space).
I could also swap out the CD/DVD drive (get one that doesn't use SATA) and get a sixth hard drive for another $100. Then I'd have 7.5 TB of advertised space, which should be plenty for now.
Is this possible? Can I simply add extra hard drives to a RAID 5 setup without losing any data? It seems completely reasonable - I can't think of a good reason why not - but I want to double check before I spend money on it.
Thanks for the help!
-- Ethan
PS: The RAID controller reads: ICH8R/ICH9R/ICH10R/DO/PCH SATA RAID Controller. If that helps with anything.
Slot 5: Empty
-- Ethan
