Hi, Im trying to figure out what would be an appropriate upgrade system for backing up my dvd's would be.
Right now the system used for the backups =
AXP 1800+
ECS k7sem motherboard
384mb of ram
onboard video
20gig western digital 5400 rpm drive
4x DVD R+-/rw+-
16x dvd-rom reader
obviously very slow for what its doing =x
What i need are some suggestions on a system build that would be noticeably faster on the reincoding/shrinking of the dvd's
p4? AXP? still trying to stay kind of budget minded, so i was thinking something on the order of
Barton 2500+
shuttle AN35 (or similiar inexpensive nforce 2 ultra board) with some sort of s-ata controller
512 (256x2) of pc3200
probably just a generic video card (doesnt need fast for video encoding does it?)
80-120gig SATA 7200rpm drive
Would this make for a noticeable increase in the speed of encoding video's
If you guys have some other suggestions on what would be a good build for this (something that doesnt take an hour to make the files for the backup ) i would appreciate it. Burning speed is fine, goes plenty fast, my problem is the actual ripping/encoding portion.
AXP 1800+
384mb of ram
onboard video
4x DVD R+-/rw+-
16x dvd-rom reader
Barton 2500+
