jengelhart
- May 30, 2014
So I am planning a build in the PC-TU100b. Here is the tentative build list:
http://pcpartpicker.com/user/jengelhart/saved/8n7v6h
Any advice is welcome, but I am mainly concerned about the cooling.
I have three questions:
1) What fan should I use for the front 120mm intake (preferably available on FrozenCPU.com)
2) What CPU cooler should I use? (I am thinking either the Noctua NH-L9i or the Thermaltake AXP-100R). If you recommend either of those, what black/red/grey fan should I use for it.
3) Will the GPU (GTX760 itx) have enough room to breathe?
I want the build to be as well cooled as possible, with noise as only a secondary concern (as long as it doesn't sound like a blow-dryer
