questions on a video card
Thats a pretty low performing gfx card but then again your machine isnt stellar today either.
It depends on the games you wish to play, what quality you expect/want and the resolution you want to game in.
I would certainly go for a faster card than the 2600 anyway.
To demonstrate what is worthwhile:
My old A64x2 clocked to 2.7GHz could get approx 80% of the performance from my 8800GT.
So you need to clock your CPU as fast as it will go for a more modern gfx card and even then that may not be quick enough.
A faster gfx card than the 8800GT is also wasted unless you get a faster CPU.
i want to be able to play unreal tournament 3 and call of juarez for right now until i get some more money to build a better computer
HD 2600Pro is too weak man especially for call of juarez. What size LCD do you have? What's your budget? I was able to play UT3 on Win XP at 1440 x 900 with an X1650 Pro on an Athlon 64 3000+ with 1 gig RAM.
Well... I take that back. The HD2600Pro is weak now but, it's faster than my X1650 pro video card. So, you should be able to play UT3. Call Of Juarez? Forget it. Need to build a whole new pc with a better gpu for that game.
1024x768
probably its going take me some time to get enough money to build a new pc. i rather wait then
