FelixRussia
- Aug 24, 2011
Hey Everyone,
I'm considering building my first water cooling loop and I've got what should be simple questions, but would like more experienced answers on.
I just recently rebuilt my machine in a Silverstone Raven RV02, and one of my biggest questions I've got at the moment is would I be better off getting a 360mm x 180mm radiator to fit the fans the case came with, or would a 360mm x 120mm radiator be more effective?
For reference, the plan is to have my 4670k and two 660Tis in the loop, with minimal overclocking, I'm thinking 4.0ghz tops for gaming/dvd ripping/video conversions, and little to no overclocking on the cards.
My main concern is then, would one radiator be enough to cool the CPU and the two GPUs well enough? I could put a 120mm radiator in the top fan position if it would make enough of a difference to justify it.
The loop would look something like this:
Reservoir -> Pump -> Radiator -> CPU -> GPU -> GPU -> Then back to the Reservoir
Or
Reservoir -> Pump -> Radiator -> CPU -> Secondary Radiator (120mm) -> GPU -> GPU -> Then back to the Reservoir
The main reason I want to do this is because I feel like it. I've wanted to dabble in water cooling for some time now, and I think I'm about ready to commit to it. I realize this isn't the greatest case to water cool in, and I understand this is supposed to be primarily an air cooled case, but I really like the layout. Its either this or water cool my Prodigy, but I would need to do some upgrades there to justify it.
Anyways, any and all input is appreciated, just let me know what you think! Thanks!
Or
