Hey guys.
I recently upgraded from a 4 year old Samsung T260 to a Dell U2412m. I've been meaning to switch to IPS for a while and I simply *love* the monitor.
I am, however, faced with a few problems so I am thinking about returning the U2412m and getting a U2711 instead. So if you are an existing U2711 owner, I'd appreciate you taking a moment to answer the following questions that will help me with my decision. Thanks in advance!
An alternative is to buy another U2412m, and use two of these awesome monitors. But then I would have nothing to connect my Xbox 360 to (I don't own a TV). I'm torn between 2 x U2412m or a single U2711. The U2711 would provide me with the ability to use my Xbox 360 thanks to the included HDMI port, but 2 x U2412m would allow me to use both my PC and Mac side by side instead of switching between them.
- Is the U2711 fast with switching between different inputs? I plan to connect it to my Desktop PC and Macbook Pro at native resolutions (2560x1440) and an Xbox 360 at 1080p. Will the monitor switch between these in a few seconds or lower? How long does it take to switch between displays from the moment you press the button?
- If the monitor goes to sleep as per PC settings, how long for the monitor to restore its display upon moving the mouse? Do you have to wait for several seconds or does it power up the display rather quick (how quick)?
- If you run a game at 2560x1440 resolution and set that resolution using in-game settings, it is the graphics card that renders the game at that resolution, right? I.E. I won't be using the scalar in the monitor?
- Have you ever experienced any noticeable input lag? If so, in which game/genre and by how much?
- What happens to the blue power light at the bottom right of the monitor when it goes to sleep? Does it turn amber and remain solid? Does it blink?
- Is the infamous anti-glare coating on the U2711 the same as that on the U2412m? I hardly notice and am not bothered by the AG on the U2412m, so it will be a sigh of relief to discover that the U2711 uses the same level of AG coating. Or is the U2711's specifically worse/more extreme than the U2412m's?
