Jimmy the Greek
- Aug 20, 2002
At the start of the weekend, I upped my FSB to 333 and increased the CPU voltage to 1.35, and my Conroe has run at a stable 3GHz since. It idles at 32/29, and reached 48/46 after a couple of hours of Orthos.
Even though it seems to be working well, I still have a couple of questions:
1) Even though I set the CPU voltage to 1.35, the BIOS and CPU-Z report it between 1.296 and 1.304. Which is more likely to be accurate? If the latter, does this mean that I have more headroom and can reach 3GHz at a lower voltage?
2) While I modified the CPU and memory voltages, I left the others (FSB, nForce, etc) as "Auto". Are these more or less irrelevant, or can auto voltages be a concern on an overclocked system? At the moment, nVidia MonitorView reports them as:
Are these voltages reasonable? (FWIW, FSB and PCI-E are accompanied by red icons, while the others have green.)FSB: 1.4V
HT (SPP-MCP): 1.2V
PCI-E: 1.4V
nForce: 1.5V
AUX: 1.5V
