1. How can I connect my 3-way SLi setup for watercooling? I have my gpublocks, but not sure what to use to connect them. I've seen koolance and danger den adapters, but I want to know what you guys did to have a little tube between them.
2. I want to get compression fittings ID 1/2 OD 3/4 so I need that size tube, correct?
3. Do you use compression fittings on the entire loop or use barbs on the radiater and pumps.
...This is obviously my first attempt at water cooling and I want to make it as clean as possible.
I'll post pics as I progress. Thanks!
