- Jan 17, 2010
Hello. Building a monster rig. Looking at the WD Raptors for Windows drive.
There are 2 versions of the 3.5" drive. 3.5-inch (backplane-ready) *And* 3.5-inch (SATA cable connect). The SATA cable connect only comes in 300GB, but I just need 150GB.
Should I just get the backplane-ready one?
What are the differences between the two?
Is there any difference between the 2.5" and the 3.5" backplane one besides the included heatsink on the 3.5" one?
Would it be better to get the 2.5" one and provide it with its own cooling/heatsink? Do these get hot enough that I should include them (I will be getting two of them) in 1 of the 2 watercool loops?
I am new with RAID stuff, I can RAID 0 these, right?
How would these compare to the OCZ Solid 2 Series SATA II 2.5" SSD? I don't know any pros/cons between HDD's and SSD's. The 60GB SSD costs a bit lower than the Raptor. The Raptor can be had for around $165-ish. The 60GB SSD for around $145-ish. Can you RAID SSD's? I guess there wouldn't be a need to unless SSD's can fail like HHD's can. I dunno. I'd go with the 30GB which costs even less but the read/write is lowerso the 60GB should be quite enough for a Win7 OS drive.
THANX
THANX
