Top Nurse said:Water cooling typically affects the difference betwen your idle and load temps. Your heat producers still put out heat. It just is removed faster and in a more efficient way.
qbackin said:Tell me about it, I have 2 serious heaters in my small room. And a third box by my feet![]()
Yes w/c will make the temps of your cpu and gpu lower. I just ordered the Swiftech Apex kit for my PD 830, it is probably the best and easiet kit out. I personally wanted a pre-built kit b/c this is my first step into w/c.
Have a look at it here: http://www.jab-tech.com/product.php?productid=3041
qbackin said:I was infact able to get one of the 4 in the first "shipment"![]()
But sidewinder has them in stock right now.
http://www.sidewindercomputers.com/swh2edukit.html
anthongy817 said:has it alaready been shipped to you? i'd like to see more comments on the kit as well =]
qbackin said:No, I will be getting it on Friday. It will surely be installed on SatI will be posting results, and considering a worklog.
The performance of the kit should be easy to read. It is up against some hefty competition with my PD 830Which runs considerably warm.
http://valid.x86-secret.com/show_oc.php?id=25730
(-40c P/C - Not my work but my exact cpu)
Erasmus354 said:What TN was referring to was that your room will still heat up as if you had air cooling, which is true. This is because the heat of your computer still gets moved into the room eventually.
What you are referring to, as I understand it however, is the case temperature. In this you are correct in your assumption. Watercooling your CPU and GPU will greatly reduce your internal case temperature (if you have the radiator external or so that the fans are exhausting). This is because the watercooling is taking out the two most significant heat sources from your computer. Their heat is now being dissipated away from the other components, which helps to lower temperatures.
Bio-Hazard said:The Swifty radiator has a surface area of 5" x 9.3" (46.5 sq in) and a Bonie (2.302) heater core has a surface area of 5.625" x 10.75" (60.475 sq in). The heater core is also much thicker and very un-restrictive air flow wise.................![]()
anthongy817 said:yeah i've been eyeing that kit. I've joined the groupbuy as well...but they don't even have a eta on when there will be more shipments. I hate my comp right now because it's so loud with all the fans and it's still so hot.
-3 120mm fans
-4 80mm fans
-zalman vf700-cu
-zalman 7700
-and the freaking chipset fan that is spinning at 7337rpms.
Temps. Idle/Load:
CPU 30/49c
PWM IC: 40/47c
Chipset: 44/52c
GPU: 59/82c
Fawkes said:Try using smart guardian to slow down the chipset fan, my spins and 2000rpm, and although my chipset gets warm (55c @ 1.7v) id rather have it warm then my ears bleeding. doesnt affect stability at all.
