Hey guys, I'm thinking about getting onto the water cooling scene, but I have a lot of things to figure out. I hope you can help:
- I know that "self-contained" systems like the Corsair Hydro series do not have an external reservoir and pump and all those doohickeys(<- Not marked wrong). Is it possible to make a CPU loop that only has a CPU block being connected with tubing to a radiator so that the whole thing is compact?
- I'd like to water cool my CPU, then if I see that WC is for me I'd get into GPU cooling and all that jazz. The GPU is actually what I'm more excited to water cool but right now I have a 9600GT so there's no sense in doing that right now. The top of the case I have(NZXT Lexa S) has two fan mounts which can accomodate (2) 120mm or (2) 140mm fans. Would a 240 or 280 radiator be acceptable for an i5 750 and would the top of the case be a good place to put the radiator? I'd like to add that I want a 240 or 280 for the sake of future-proofing so that I don't have to upgrade for the CPU loop in the event that I change the CPU one day.
