Questions about this build
darkhunter139
Ok well my first questions is would you trust the PSU in this case?
http://www.newegg.com/product/product.aspx?item=N82E16811208011
Here is the build I have so far
XION Solaris XON-401 Black with Green LED Light Steel ATX Mid Tower Computer Case 450W Power Supply - Retail
GIGABYTE GA-73PVM-S2H LGA 775 NVIDIA GeForce 7100 HDMI Micro ATX Intel Motherboard - Retail
EVGA 512-P3-N801-AR GeForce 8800GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
CORSAIR CMPSU-550VX 550W ATX12V V2.2 Power Supply - Retail (if case one isnt good enough)
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model BX80562Q6600 - Retail
Seagate ST303204N1A1A-RK 320GB 7200 RPM IDE Ultra ATA100 Hard Drive - Retail
Model #: ST303204N1A1A-RK
LITE-ON 20X DVD±R DVD Burner Black IDE Model DH-20A4P-04 - OEM
No. The only bundled-with-the-case PSUs that I would trust are those from the Antec EarthWatts line of PSUs.
How much (total) do you have to spend on your entire build? And how much are you willing to spend on the case and/or power supply?
Think I can get away with a cheaper video card if I dont want it for gaming? I want to be able to watch stuff in HD though
why are you going with a board that has built in graphics, and you are going to add in a card anyway?
yes you could go with the 9600GT which, where i am is cheaper than the 8800GT, but is only slightly less performance wise...
yo ushould really consider a sata HDD and a sata DVD drive, as they will be considerably faster compared to the ide drives you have, particularly the new western digital 320GB drives, which fit an entire 320GB on a single data platter, making them much faster than other drives...
I already ditched those drives I added them by mistake
What motherboard should I go with? That was the cheapest i saw
definately a P35, e.g:
gigabyte P35 DS3R/L/P
Asus P5K - E wifi AP
Abit IP35 PRO etc
Alright budget is like 700 dolllars.
Whats the best build I could put together for that price?
Case: ~$100 - your choice, make sure it has all 120mm fans, at least 2, 3 or 4 preferred.
PSU: ~$100 - Corsair TX 750 (overkill but can't be beat for the price)
CPU: E2xxx series (OC to ~3Ghz) - $70
Motherboard: MSI P35-Neo2-FR - $110
RAM: A-Data 4GB DDR2-800 - $65
GPU: MSI 8800 GTS 512MB - $225
HDD: 500GB WD 7200RPM SATA - $75
Optical: Samsung SATA 20X DVDRW - $35
HSF: Xigmatech Rifle 120mm HSF - $35
So that puts you at around $800 before shipping. Find a case cheap and knock $50 off that. Swap the $225 8800 GTS 512MB for a ~$160 9600 GT 512MB and knock $65 off. Swap the MSI P35 Neo2-FR for a Gigabyte P35-DS3L and save $30 There you go.
Here, lemme swap for silent...
Case: CM Elite 330 - $50
Motherboard: Gigabyte GA-EP35-DS3L - $90
GPU: ECS 9600GT - $150
Case/PSU:
$105 - Antec Sonata III Super Mini-Tower w/ Earthwatts 500w Power Supply - SONATA III
CPU/HSF:
I'd rather go for a $134 E7200 with stock cooling rather than buy an E2180 with a high-end HSF. It will also reach a higher threshold in overclocking and performs better per clock.
Motherboard:
$65 - GIGABYTE GA-P31-S3G LGA 775 Intel P31 ATX Intel Motherboard - Retail
If it does the job and overclocks decently, then why not???
RAM:
$63 (EMCAFAJAG) - A-DATA 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
Graphics Card:
The 9600GT is nice, but the 8800GTS is better...
HDD:
There's a deal on a 7200.10 at ZZF($75), but it's only $5 cheaper than that in newegg.com. I couldn't find any cheaper prices on 500GB harddrives...
go for the 640GB Western Digital drive, is quicker than the raptors in most situations, and you get more GB's
