I'm thinking about making the jump to a 120/144Hz monitor (maybe the Swift). I know the high refresh rates offer "smoother" gameplay, but what is it like if you are not maintaining 120 or 144 fps?
Here's why I ask- Anytime I go under 60fps I can immediately see/feel it. Seriously, I drop one frame and I feel lag. (Maybe it's some SLI stuttering? But doesn't that only occur when you go over x frames in x Hz, not under?)
Now lets look at consoles. Most games are locked at 30fps and when I play them on the same display, it feels fine-ish. It's certainly not as smooth but it doesn't create that same type of chunkyness that I get if I drop to 59fps.
So back to my initial question, will anything less than 120 or 144 fps give me that same kind of feeling? Or will I still maintain that normal 60fps smoothness as long as I am above 60 fps and anything higher than 60fps will be displayable?
I am the kind of person that likes to max games out so upgrading my GPUs will probably come during Maxwell gen 2. Maintaining that high framerate while maxed out is definitely a concern of mine and a pair of 980's doesn't seem enough.
