YeOldeStonecat said:http://www.speedguide.net/read_articles.php?id=177
You don't need to open/forward 80 ports...you do a "range"..just like you listed above.
Don't need a static IP address for temporary servers...clients connect to your current WAN IP address.
Most new game servers will keep "heartbeats" to master game server lists..people will find it via name anyways.
You want a low system impact antivirus, exclude your game directory from real time file protection.
Hopefully you're not "playing" on the same machine that your "serving" on...run a dedicated server. If you also play as a client..your CPU is being HAMMERED trying to provide your graphics, etc..making it laggy for your clients.
Maul said:So if I've assigned my Computer a 192.168.0.200 address on my network that will be the IP address I forward ports to? SO that would allow internet users to connect to my internal ip address assigned by my ISP?
Also, about Antivirus/firewall software. Should I put the settings to Low protection? Or should I just shut it down till I get my router configured correctly?
